Philco radio from 1971 Ford F100
mast to ground- no current
center plug to mast - 5 ohms
shield to ground - no current
center plug to shield - no current
That 1953 Cevy sounds great. I drove my grandfather's '55 ford farlane for a while - I wish I still had it!
Philco radio from 1971 Ford F100 - by Guest - 12-02-2008, 11:17 PM
Re: Philco radio from 1971 Ford F100 - by exray - 12-02-2008, 11:50 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 01:26 AM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-03-2008, 03:59 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 10:30 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 11:16 AM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-04-2008, 03:09 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 07:51 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 01:21 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-05-2008, 03:53 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 11:24 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 10-30-2009, 01:40 PM
