Here we go with a Brand Z 9-S-262
The Riders info included the alignment procedure. Thirtiesradio, does your Zenith service manual include an under-chassis drawing for the 9-S-262, or did Zenith just not produce any of those? I'm slowly making progress replacing caps and resistors, but a factory under-chassis drawing would sure help.
I did download Geoff's handmade under-chassis drawing, which has helped.
I wouldn't even mention it if this chassis had not been molested...but since it has been hacked, I'd like to make sure the wires are connected as they should be. As one example of a hack, a previous owner had the suppressor grid of the 6K7 RF amp connected to the screen grid of the 6L7.
RE: Here we go with a Brand Z 9-S-262 - by Ron Ramirez - 12-24-2014, 04:23 PM
Users browsing this thread: 34 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
