37-38-116 and 116X clarifiers
He chose this cloth because it came in a 24 x 24 size and he liked how it looked. This radio is in his personal collection. You need two pieces of the 24 x 18 cloth everyone sells to do it as designed.
37-38-116 and 116X clarifiers - by Ronin61 - 12-24-2014, 06:26 PM
RE: 37-38-116 and 116X clarifiers - by morzh - 12-24-2014, 06:48 PM
RE: 37-38-116 and 116X clarifiers - by Ronin61 - 12-24-2014, 06:57 PM
RE: 37-38-116 and 116X clarifiers - by morzh - 12-24-2014, 08:58 PM
