HELP - Broken grille, Philco Tropic 41-758EZ
Replicate? No, Ron go with the idea of a stiffing piece glued to the back. Just a matter of finding an adhesive that will bond nicely. I'm surprised JB didn't do the job but the narrow gaps may have been the problem. I would just align the pieces and glue from the back with something like a thin stiff piece of metal. Something like the edge of a wood ruler sounds like an excellent idea. Good luck and glad your back.
Jerry
RE: HELP - Broken grille, Philco Tropic 41-758EZ - by jerryhawthorne - 12-24-2014, 07:55 PM
There are currently 9595 online users. [Complete List]
» 3 Member(s) | 9592 Guest(s)
