Here we go with a Brand Z 9-S-262
(12-25-2014, 12:21 AM)Geoff Wrote: Did Philco create under chassis drawings?
Yes! Not for every model (I recall some of the little Transitone home radios not having these), but most Philcos did have these.
From 1928 to early 1930, up to the model 111, Philco factory service info included a photo of the underneath of the chassis. The photos did not always reproduce well or clearly show details, so beginning with model 46, Philco switched to under-chassis drawings. These did not show all of the wiring, but do show placement and position of capacitors, resistors and other parts...which helps when you are in unfamiliar territory.
RE: Here we go with a Brand Z 9-S-262 - by Ron Ramirez - 12-25-2014, 09:06 AM
Users browsing this thread: 30 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
