40-165 Radiobar Zephyr restoration
The liquor cabinet door was bent at a severe angle.  To repair this a woodworker friend of mine made a series of cuts on the back side and inserted wedges to straighten the door.
repairing bent door
To fix the horrible patch on the front bar door my friend cut out a knot of burled walnut veneer that matched pretty well and glued it in place.  Since the veneer was bookmarked he hand  painted a mirror image of the knot on the other door.
doors after veneer repair
The other veneer patch was much easier to repair.
side veneer patch
Here it is ready for re-finishing
ready for Lacquer
after numerous coats of lacquer
Cabinet  finished
cabinet finished
cabinet finished open
To repair the crushed antenna I made a plywood and presentation board sleeve to restore the shape of the shield.
sleeve for antenna
antenna reformed with internal sleeve
More to come soon.
Keith
RE: 40-165 Radiobar Zephyr restoration - by keith49vj3 - 12-25-2014, 12:34 PM
RE: 40-165 Radiobar Zephyr restoration - by sam - 01-25-2015, 08:27 PM
There are currently 4999 online users. [Complete List]
» 3 Member(s) | 4996 Guest(s)
