The radio was turned on a played when hooked up to another speaker, so I had to reason the problem was the speaker. The speaker we used is not available. The gentleman who I did this with worked on Philcos in the 40's and 50's. Sorry for the delay, but I'm on 12 hr shifts for the weekend.
46-1226 - by teamtnt - 05-19-2011, 10:27 PM
Re: 46-1226 - by ipwizard - 05-20-2011, 06:58 PM
Re: 46-1226 - by teamtnt - 05-21-2011, 04:17 AM
Re: 46-1226 - by Arran - 05-22-2011, 12:44 AM
Re: 46-1226 - by teamtnt - 05-22-2011, 12:32 PM
Re: 46-1226 - by codefox1 - 05-22-2011, 02:43 PM
Re: 46-1226 - by Arran - 05-22-2011, 09:43 PM
