Safe to powerup without Speaker?
Yes, I definitely need some sort of temporary speaker set up. At the moment I get a loud ticking sound on AM and a hum on shortwave. I need to get this onto my bench for trouble shooting. If I use a PM speaker what kind of wattage do I need for the resistor to replace the 1700 ohm field coil?
Keith
Safe to powerup without Speaker? - by keith49vj3 - 12-25-2014, 05:00 PM
RE: Safe to powerup without Speaker? - by David - 12-25-2014, 09:37 PM
RE: Safe to powerup without Speaker? - by OZ4 - 12-25-2014, 09:56 PM
RE: Safe to powerup without Speaker? - by morzh - 12-25-2014, 10:02 PM
RE: Safe to powerup without Speaker? - by morzh - 12-26-2014, 12:54 AM
RE: Safe to powerup without Speaker? - by joejoe - 12-27-2014, 12:36 AM
RE: Safe to powerup without Speaker? - by keith49vj3 - 12-27-2014, 03:40 PM
RE: Safe to powerup without Speaker? - by morzh - 12-27-2014, 05:14 PM
RE: Safe to powerup without Speaker? - by OZ4 - 12-27-2014, 05:22 PM
RE: Safe to powerup without Speaker? - by Warren - 12-27-2014, 06:11 PM
RE: Safe to powerup without Speaker? - by morzh - 12-28-2014, 05:14 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
