Tis the season...
The raspy hum caused by a turned-off set of Christmas lights does seem a bit odd.
Where I live, the local talk station often has hum in it. It is the station's fault...when the hum is there, it is there no matter what radio one uses to listen to it, be it at home or in the car.
As to the lacquer finish...much better than stain and poly, yes?
Tis the season... - by DCASAZZA - 12-05-2008, 10:41 AM
Re: Fa la la la la... - by Ron Ramirez - 12-07-2008, 02:12 PM
Re: Tis the season... - by BDM - 12-07-2008, 08:00 PM
