All of the paper and electrolytic capacitors must be replaced for optimum results.
Most likely, bad electrolytics are causing your hum as Eric said. Leaky paper caps are probably the reason why the phonograph still produces sound but the radio does not work.
46-1209 - by Guest - 12-05-2008, 10:12 PM
Re: 46-1209 - by Guest - 12-06-2008, 08:19 PM
Re: 46-1209 - by Ron Ramirez - 12-07-2008, 02:15 PM
Re: 46-1209 - by Guest - 12-07-2008, 04:56 PM
Re: 46-1209 - by Ron Ramirez - 12-07-2008, 07:56 PM
Re: 46-1209 - by Guest - 12-09-2008, 12:07 PM
Re: 46-1209 - by Ron Ramirez - 12-09-2008, 02:10 PM
Re: 46-1209 - by Guest - 12-10-2008, 08:17 PM
Re: 46-1209 - by Guest - 01-22-2009, 03:01 PM
Re: 46-1209 - by Ron Ramirez - 01-22-2009, 06:57 PM
Re: 46-1209 - by Michael Dennis - 01-23-2009, 04:21 PM
Eico 232 VTVM Schematic
There are currently 8901 online users. [Complete List]
» 2 Member(s) | 8899 Guest(s)
