Philco 70 Cathedral Speaker
#46
To add to that, the resistance, coil to coil, was very consistent, all those I had read very close to what it said on the sch, between 3.1-3.2K.
And in 70 this does affect pretty much very tube's plate DC. Will still work but may run hotter.
Philco 70 Cathedral Speaker - by Ron Ramirez - 11-27-2014, 08:07 AM
RE: Philco 70 Cathedral Speaker - by KCMike - 11-27-2014, 10:46 AM
RE: Philco 70 Cathedral Speaker - by morzh - 11-27-2014, 12:50 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 11-27-2014, 02:44 PM
RE: Philco 70 Cathedral Speaker - by Ron Ramirez - 11-27-2014, 05:15 PM
RE: Philco 70 Cathedral Speaker - by Arran - 11-28-2014, 01:01 AM
RE: Philco 70 Cathedral Speaker - by morzh - 11-28-2014, 12:37 PM
RE: Philco 70 Cathedral Speaker - by Arran - 11-29-2014, 04:01 AM
RE: Philco 70 Cathedral Speaker - by klondike98 - 11-29-2014, 11:13 AM
RE: Philco 70 Cathedral Speaker - by Ron Ramirez - 11-29-2014, 11:30 AM
RE: Philco 70 Cathedral Speaker - by morzh - 11-29-2014, 11:56 AM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-04-2014, 11:11 PM
RE: Philco 70 Cathedral Speaker - by Warren - 12-04-2014, 11:23 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-04-2014, 11:41 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-05-2014, 12:01 AM
RE: Philco 70 Cathedral Speaker - by morzh - 12-05-2014, 04:09 PM
RE: Philco 70 Cathedral Speaker - by radiohenry - 12-05-2014, 06:06 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-05-2014, 06:31 PM
RE: Philco 70 Cathedral Speaker - by radiohenry - 12-05-2014, 07:00 PM
RE: Philco 70 Cathedral Speaker - by KCMike - 12-05-2014, 06:31 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-05-2014, 07:12 PM
RE: Philco 70 Cathedral Speaker - by Arran - 12-09-2014, 01:24 AM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-05-2014, 11:05 PM
RE: Philco 70 Cathedral Speaker - by Arran - 12-09-2014, 01:36 AM
RE: Philco 70 Cathedral Speaker - by morzh - 12-05-2014, 11:28 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-05-2014, 11:51 PM
RE: Philco 70 Cathedral Speaker - by KCMike - 12-06-2014, 04:41 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-07-2014, 02:36 AM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-08-2014, 09:24 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-08-2014, 09:30 PM
RE: Philco 70 Cathedral Speaker - by Ron Ramirez - 12-08-2014, 10:01 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-09-2014, 10:42 AM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-09-2014, 12:44 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-09-2014, 03:30 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-27-2014, 02:26 AM
RE: Philco 70 Cathedral Speaker - by morzh - 12-27-2014, 01:24 PM
RE: Philco 70 Cathedral Speaker - by Ron Ramirez - 12-27-2014, 07:09 PM
RE: Philco 70 Cathedral Speaker - by 462ron - 12-27-2014, 08:30 PM
RE: Philco 70 Cathedral Speaker - by Arran - 12-28-2014, 10:12 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-27-2014, 09:18 PM
RE: Philco 70 Cathedral Speaker - by 462ron - 12-27-2014, 10:40 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-28-2014, 07:48 PM
RE: Philco 70 Cathedral Speaker - by morzh - 12-28-2014, 10:17 PM
RE: Philco 70 Cathedral Speaker - by Arran - 12-28-2014, 11:06 PM
RE: Philco 70 Cathedral Speaker - by Steve Davis - 12-29-2014, 07:49 AM
RE: Philco 70 Cathedral Speaker - by morzh - 12-29-2014, 05:46 PM
There are currently 7057 online users. [Complete List]
» 2 Member(s) | 7055 Guest(s)
