Philco 59 Antenna Transformer
No. First it is a regen.
And it needs alignment.
Without this you are not getting anything very loud save the local stations.
Philco 59 Antenna Transformer - by cparsons2391 - 12-28-2014, 11:31 AM
RE: Philco 59 Antenna Transformer - by morzh - 12-28-2014, 01:05 PM
RE: Philco 59 Antenna Transformer - by morzh - 12-28-2014, 06:55 PM
RE: Philco 59 Antenna Transformer - by morzh - 12-29-2014, 06:09 PM
RE: Philco 59 Antenna Transformer - by codefox1 - 12-30-2014, 01:14 AM
