Philco 19-128 dial string diagram
(12-29-2014, 12:01 PM)jeffb Wrote:  Hello and thanks for adding me to this forum! Does anyone have a dial string diagram for Philco 19-128 console radio? Any help would be greatly appreciated, thanks!
There is no such model, that sounds like a part number for as paper label, not a model number. There is a Philco model 19, but no Philco 128 that I am aware of, an RCA-Victor model 128 but not a Philco 128.
Philco 19-128 dial string diagram - by jeffb - 12-29-2014, 12:01 PM
RE: Philco 19-128 dial string diagram - by Arran - 12-30-2014, 02:12 AM
RE: Philco 19-128 dial string diagram - by jeffb - 12-30-2014, 08:10 AM
There are currently 10370 online users. [Complete List]
» 1 Member(s) | 10369 Guest(s)
