Model 116 feq range
Evening ,
I am finishing up the chassis restoration of my model 116. My question being--should there be any "stations" on band 5?? The freq range is 150-390Kc----well below the broadcast band. The schematic states it is a weather frequency band. Anything out there?
Thanks guys!
Dave
Model 116 feq range - by Dave Slusarczyk - 12-08-2008, 01:16 AM
Re: Model 116 feq range - by rghines1 - 12-08-2008, 09:07 AM
Re: Model 116 feq range - by etech - 12-08-2008, 10:34 AM
Re: Model 116 freq range - by BDM - 12-09-2008, 12:07 AM
There are currently 4375 online users. [Complete List]
» 4 Member(s) | 4371 Guest(s)
AvatarAvatarAvatarAvatar
