Model 90 cabinet veneer
Thanks radiomikee!
I did some exploring around the local woodworking places, and concluded
as well it was walnut... and now I have some good veneer to work with!
This radio may have an interesting history. At some time it sat for a short
period in some floodwater (and there was a BIG flood in 1950 here) and there
was some evidence of Red River mud in some of the nooks and crannies of
the woodwork. The '50 flood is only a guess, of course.
It was only about two inches of water, but that sure loosened
up the bottom board. I've been regluing that and flattening the bottom
veneer piece of the plywood which came off completely and wrinkled up. Want to
keep that on the radio; it's stamped "May 11 1931".
Thanks again for your response!
Nelson
Model 90 cabinet veneer - by Guest - 12-02-2008, 11:53 PM
Re: Model 90 cabinet veneer - by radiomikee - 12-07-2008, 08:27 PM
Re: Model 90 cabinet veneer - by Guest - 12-08-2008, 02:04 AM
Re: Model 90 cabinet veneer - by Ron Ramirez - 12-09-2008, 02:21 PM
Eico 232 VTVM Schematic
There are currently 9015 online users. [Complete List]
» 1 Member(s) | 9014 Guest(s)
