Great Tube Substitution Manual!
Thanks Texasrocker for the tip! This one goes into a lot of detail that I've never seen before about any necessary modifications.
While on the subject, another worth looking for that concerns direct substitutions w/o making any modifications is a Rider publication written by H. A. Middleton. Name on mine is 1963 Tube Caddy, tube substitution guidebook. It simply rates the substitutes with a good or excellent rating.
Richard
Great Tube Substitution Manual! - by Texasrocker - 12-08-2008, 01:10 AM
Re: Great Tube Substitution Manual! - by rghines1 - 12-08-2008, 09:23 AM
There are currently 10441 online users. [Complete List]
» 2 Member(s) | 10439 Guest(s)
