Model 116 feq range
With a good longwire antenna, I am able to receive quite a few of navigation beacons on the longwave band. But also, you can listen for dx broadcast stations on that band , if you have a good antenna. Here is some information I received from Brian (BDM) on longwave broadcasting from ITU region 1.
http://en.wikipedia.org/wiki/Long_wave
The propagation on this band is particularly good for dx-ing this time of year (winter) during the nighttime hours.
Ed
Model 116 feq range - by Dave Slusarczyk - 12-08-2008, 01:16 AM
Re: Model 116 feq range - by rghines1 - 12-08-2008, 09:07 AM
Re: Model 116 feq range - by etech - 12-08-2008, 10:34 AM
Re: Model 116 freq range - by BDM - 12-09-2008, 12:07 AM
There are currently 10027 online users. [Complete List]
» 1 Member(s) | 10026 Guest(s)
