Philco Model 95
(12-27-2014, 12:18 PM)klondike98 Wrote:  Hi Chris, welcome to the Phorum!  Unfortunately I can't answer your questions but since no one had responded yet I just wanted to welcome you and let you know there will likely be someone who can help.
Thank You
Bob. I appreciate the reply.
Chris H
N9WHH
Philco Model 95 - by Chris h - 12-26-2014, 09:41 PM
RE: Philco Model 95 - by klondike98 - 12-27-2014, 12:18 PM
RE: Philco Model 95 - by Chris h - 12-30-2014, 04:55 PM
RE: Philco Model 95 - by Ron Ramirez - 12-28-2014, 10:49 PM
RE: Philco Model 95 - by Chris h - 12-30-2014, 04:56 PM
RE: Philco Model 95 - by Chris h - 01-18-2015, 10:46 PM
RE: Philco Model 95 - by Kestas - 01-19-2015, 09:50 AM
RE: Philco Model 95 - by Chris h - 01-19-2015, 02:09 PM
RE: Philco Model 95 - by klondike98 - 01-19-2015, 10:45 AM
