Philco 37-670 restoration thread
 Sounds like the pin-out of a 5X4 is like that of a 5Y4, so 7-8 for the filament. I would not make the assumption that whomever put the 5U4 in there knew what they were doing, anybody can stuff a tube in a socket.
Philco 37-670 restoration thread - by Diverted - 12-30-2014, 03:55 PM
RE: Philco 37-670 rectifier - by millievolt - 12-30-2014, 04:25 PM
RE: Philco 37-670 rectifier - by Diverted - 12-30-2014, 05:03 PM
RE: Philco 37-670 rectifier - by Chuck Schwark - 12-30-2014, 04:28 PM
RE: Philco 37-670 rectifier - by millievolt - 12-30-2014, 04:33 PM
RE: Philco 37-670 rectifier - by morzh - 12-30-2014, 06:27 PM
RE: Philco 37-670 rectifier - by Diverted - 12-30-2014, 07:45 PM
RE: Philco 37-670 rectifier - by OZ4 - 12-30-2014, 08:14 PM
RE: Philco 37-670 rectifier - by Diverted - 12-30-2014, 08:35 PM
RE: Philco 37-670 rectifier - by OZ4 - 12-30-2014, 09:10 PM
RE: Philco 37-670 rectifier - by thirtiesradio - 12-31-2014, 03:44 AM
RE: Philco 37-670 rectifier - by Arran - 12-31-2014, 04:54 AM
RE: Philco 37-670 rectifier - by Diverted - 12-31-2014, 09:03 AM
RE: Philco 37-670 restoration thread - by John R - 12-31-2014, 05:19 PM
RE: Philco 37-670 restoration thread - by OZ4 - 12-31-2014, 01:03 PM
