xf 19
Well...there...you...go. Mystery solved. Icon_smile
To answer your intital question about your set...find a copy of the most recent edition of Slusser's "Collector's Guide to Antique Radios." It is available at many bookstores and antique malls, and via this link:
http://astore.amazon.com/philcoradiocom/...1574325493
xf 19 - by Guest - 11-19-2008, 10:33 PM
Re: xf 19 - by Texasrocker - 11-20-2008, 02:39 AM
Re: xf 19 - by Guest - 11-30-2008, 07:22 PM
Re: xf 19 - by Guest - 12-03-2008, 01:35 AM
Re: xf 19 - by Ron Ramirez - 12-03-2008, 07:50 AM
Re: xf 19 - by Guest - 12-03-2008, 10:03 PM
Re: xf 19 - by Chuck Schwark - 12-03-2008, 10:11 PM
Re: xf 19 - by Ron Ramirez - 12-03-2008, 10:52 PM
Re: xf 19 - by Guest - 12-09-2008, 12:44 AM
Re: xf 19 - by Ron Ramirez - 12-09-2008, 02:13 PM
Re: xf 19 - by Guest - 12-14-2008, 09:15 PM
Eico 232 VTVM Schematic
There are currently 10153 online users. [Complete List]
» 1 Member(s) | 10152 Guest(s)
