42-1008P What is this?
Can't tell from picture, but if it seems to be a structural support that needs to be insulated from the basket, as stators often are, a ceramic insulator would be best, (and replace missing scrrew?) but if you can trace the schematic and logic leads you to conclude it is a trimmer capacitor gone missing, well that's another story. Also could be unneeded (duplicate) connection to the stator. Dunno.
42-1008P What is this? - by Edisla - 11-01-2014, 11:02 PM
RE: 42-1008P What is this? - by Phlogiston - 11-02-2014, 12:17 PM
RE: 42-1008P What is this? - by Edisla - 11-02-2014, 11:36 PM
RE: 42-1008P What is this? - by Edisla - 12-31-2014, 01:31 AM
RE: 42-1008P What is this? - by codefox1 - 01-01-2015, 11:48 AM
RE: 42-1008P What is this? - by Edisla - 02-11-2015, 09:19 PM
RE: 42-1008P What is this? - by Edisla - 02-11-2015, 09:56 PM
RE: 42-1008P What is this? - by Edisla - 02-11-2015, 11:13 PM
RE: 42-1008P What is this? - by Ron Ramirez - 02-12-2015, 08:15 AM
RE: 42-1008P What is this? - by Edisla - 02-12-2015, 11:52 AM
There are currently 6088 online users. [Complete List]
» 1 Member(s) | 6087 Guest(s)
