40-165 Alignment adapter
In order to achieve an accurate and thorough alignment on a Philco set which uses a built-in loop antenna, it is required that the loop be connected during the alignment procedure.
40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 12:47 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 03:18 PM
RE: 40-165 Alignment adapter - by Nick3092 - 12-31-2014, 03:23 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 05:11 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 05:26 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 06:12 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 08:32 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 08:20 AM
RE: 40-165 Alignment adapter - by codefox1 - 01-01-2015, 11:58 AM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 01:04 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 03:34 PM
RE: 40-165 Alignment adapter - by klondike98 - 01-01-2015, 03:44 PM
RE: 40-165 Alignment adapter - by Ron Ramirez - 01-01-2015, 05:03 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-04-2015, 05:02 PM
RE: 40-165 Alignment adapter - by codefox1 - 01-04-2015, 05:11 PM
RE: 40-165 Alignment adapter - by klondike98 - 01-04-2015, 05:25 PM
