Philco 42-350 FM
I believe the pre-war FM band was 42 - 50 MHz.  The old FM numbers on the 42-350 dial face range from 21 to 99 which correspond to 42.1MHz through 49.9 MHz.  So...there's no overlap with the modern 88 - 108MHz band and 76MHz would be above the old FM band.
Philco 42-350 FM - by shaler78 - 01-03-2015, 11:39 PM
RE: Philco 42-350 FM - by klondike98 - 01-04-2015, 08:58 AM
RE: Philco 42-350 FM - by Ron Ramirez - 01-04-2015, 10:54 AM
RE: Philco 42-350 FM - by shaler78 - 01-04-2015, 03:29 PM
RE: Philco 42-350 FM - by Raleigh - 02-14-2015, 05:39 PM
