under chassis pic philco 90
That's the one alright.
Thanks for the help. It will help a lot.
Obviously someone has taken some shortcuts on mine.
murf
under chassis pic philco 90 - by murf - 01-04-2015, 11:11 AM
RE: under chassis pic philco 90 - by Kestas - 01-04-2015, 12:12 PM
RE: under chassis pic philco 90 - by murf - 01-04-2015, 01:30 PM
RE: under chassis pic philco 90 - by Kestas - 01-04-2015, 03:46 PM
RE: under chassis pic philco 90 - by murf - 01-04-2015, 04:55 PM
RE: under chassis pic philco 90 - by codefox1 - 01-04-2015, 05:17 PM
RE: under chassis pic philco 90 - by Kestas - 01-04-2015, 08:20 PM
