40-165 Alignment adapter
Thanks everyone, I finally ended up getting the set aligned. It turns out that I had a bad connector on my Eico Signal generator that was complicating matters. The radio plays pretty well and by un-soldering one wire on the volume control I was able to add a connection for an MP3 adapter. I used this design for my MP3 adapter http://www.antiqueradios.com/forums/view...f6f0b5d4e6 I just ordered a bluetooth receiver so I should be able to play the radio using bluetooth from my phone.
Keith
40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 12:47 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 03:18 PM
RE: 40-165 Alignment adapter - by Nick3092 - 12-31-2014, 03:23 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 05:11 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 05:26 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 12-31-2014, 06:12 PM
RE: 40-165 Alignment adapter - by klondike98 - 12-31-2014, 08:32 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 08:20 AM
RE: 40-165 Alignment adapter - by codefox1 - 01-01-2015, 11:58 AM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 01:04 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-01-2015, 03:34 PM
RE: 40-165 Alignment adapter - by klondike98 - 01-01-2015, 03:44 PM
RE: 40-165 Alignment adapter - by Ron Ramirez - 01-01-2015, 05:03 PM
RE: 40-165 Alignment adapter - by keith49vj3 - 01-04-2015, 05:02 PM
RE: 40-165 Alignment adapter - by codefox1 - 01-04-2015, 05:11 PM
RE: 40-165 Alignment adapter - by klondike98 - 01-04-2015, 05:25 PM
