220, 220A?
Thanks everyone.  I should have consulted the "Philco bible according to Ron Ramirez"  before I bothered you.  I knew the 20 was built as a cathedral and consoles,  but never knew it was produced with a turntable also.  Take care, Gary
220, 220A? - by GarySP - 01-04-2015, 01:59 PM
RE: 220, 220A? - by klondike98 - 01-04-2015, 02:45 PM
RE: 220, 220A? - by Ron Ramirez - 01-04-2015, 03:16 PM
RE: 220, 220A? - by morzh - 01-04-2015, 03:26 PM
RE: 220, 220A? - by Ron Ramirez - 01-04-2015, 03:29 PM
RE: 220, 220A? - by morzh - 01-04-2015, 03:47 PM
RE: 220, 220A? - by jerryhawthorne - 01-04-2015, 04:19 PM
RE: 220, 220A? - by GarySP - 01-04-2015, 09:53 PM
There are currently 9783 online users. [Complete List]
» 3 Member(s) | 9780 Guest(s)
