Here we go with a Brand Z 9-S-262
#69
A little late for this project, but if you have issues in the future with rod stock being too large a diameter for the project just chuck an end into a drill, and wrap some 320 grit sandpaper around it. Fire up the drill and hold the sandpaper tightly around the rod.  Slide the sandpaper back and forth until  the diameter is decreased enough.  Aluminum is fairly soft, so it shouldn't take long at all to get the diameter right.  Take care, Gary
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-22-2014, 03:36 PM
RE: Here we go with a Brand Z 9-S-262 - by murf - 12-24-2014, 12:16 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 03:59 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 04:04 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 09:38 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-23-2014, 01:04 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-23-2014, 06:22 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-23-2014, 06:32 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 12-24-2014, 05:27 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-24-2014, 11:25 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-24-2014, 06:12 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-24-2014, 11:21 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 12:16 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-25-2014, 12:39 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 12:21 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 06:03 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 12-25-2014, 01:59 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 02:57 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 03:18 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-26-2014, 12:00 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 03:16 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-28-2014, 10:14 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-01-2015, 11:07 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-30-2014, 06:34 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-31-2014, 04:03 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-01-2015, 02:43 AM
RE: Here we go with a Brand Z 9-S-262 - by murf - 01-01-2015, 09:10 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-04-2015, 02:19 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-03-2015, 10:22 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-03-2015, 10:45 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 01:06 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 03:50 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 08:16 PM
RE: Here we go with a Brand Z 9-S-262 - by GarySP - 01-04-2015, 10:37 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-05-2015, 02:51 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-05-2015, 11:41 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-06-2015, 12:25 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-06-2015, 09:56 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-07-2015, 08:29 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-08-2015, 12:40 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 01:52 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 02:03 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 03:30 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-09-2015, 11:07 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-08-2015, 11:31 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-09-2015, 05:10 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-10-2015, 03:21 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-10-2015, 03:17 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-10-2015, 07:10 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-10-2015, 10:52 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-15-2015, 10:28 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-16-2015, 02:34 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-18-2015, 02:07 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-19-2015, 12:29 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-16-2015, 09:46 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-17-2015, 02:07 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-17-2015, 01:00 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-18-2015, 01:53 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-18-2015, 12:35 PM
Users browsing this thread: 32 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
