Philco 23x opened up
Wanted to share this beautiful Philco 23x radio I have restored.
PHILCO 23x - by Fred Taylor - 01-04-2015, 10:46 PM
RE: Philco 23x opened up - by thirtiesradio - 01-06-2015, 01:20 AM
RE: Philco 23x opened up - by PhilcoJohn - 01-06-2015, 10:34 AM
RE: PHILCO 23x - by morzh - 01-04-2015, 10:56 PM
RE: PHILCO 23x - by klondike98 - 01-04-2015, 10:56 PM
RE: PHILCO 23x - by sam - 01-04-2015, 11:10 PM
Philco 23x opened up - by Fred Taylor - 01-04-2015, 11:33 PM
RE: Philco 23x opened up - by Warren - 01-04-2015, 11:35 PM
RE: PHILCO 23x - by Warren - 01-04-2015, 11:37 PM
There are currently 9733 online users. [Complete List]
» 3 Member(s) | 9730 Guest(s)
