Philco Fibre Wrench - Homebrew
Cool. Along while back, I was lucky to get a Philco original, along with the other orig Philco fiber screwdriver tip align tool and service hex set:
[Image: http://www.philcorepairbench.com/images/...ools01.jpg]
[Image: http://www.philcorepairbench.com/images/...ools02.jpg]
[Image: http://www.philcorepairbench.com/images/tools02.jpg]
Philco Fibre Wrench - Homebrew - by etech - 12-10-2008, 03:17 PM
Re: Philco Fibre Wrench - Homebrew - by Chuck Schwark - 12-10-2008, 03:39 PM
Re: Philco Fibre Wrench - Homebrew - by BDM - 12-10-2008, 04:49 PM
Re: Philco Fibre Wrench - Homebrew - by etech - 12-11-2008, 10:18 AM
Re: Philco Fibre Wrench - Homebrew - by Arran - 12-31-2008, 02:14 AM
Re: Philco Fibre Wrench - Homebrew - by Jim Berg - 01-04-2009, 01:22 AM
Re: Philco Fibre Wrench - Homebrew - by etech - 01-04-2009, 09:47 AM
Re: Philco Fibre Wrench - Homebrew - by radiorich - 02-05-2009, 05:14 PM
There are currently 9716 online users. [Complete List]
» 3 Member(s) | 9713 Guest(s)
