Chasis make overs
(01-05-2015, 08:28 AM)fields 100 Wrote:
(01-05-2015, 02:56 AM)Fred Taylor Wrote:         When restoring cabinets I like to redo the guts because most of what I get is rusted or in poor shape. I can buy them for a lot less money and that goes for the cabinet to. I enjoy repairing, and restoreing these radios, its no challenge for me if there not all jacked up.. But I do have my limatations .
What kind of paint are you using to paint the Zenith chassis?
  I first use  automotive self  etching primer/sealer  and then believe  it or not Krylon hammered copper color for top coat.
Chasis make overs - by Fred Taylor - 01-05-2015, 02:56 AM
RE: Chasis make overs - by codefox1 - 01-05-2015, 05:44 AM
RE: Chasis make overs - by fields 100 - 01-05-2015, 08:28 AM
RE: Chasis make overs - by Fred Taylor - 01-05-2015, 10:18 AM
RE: Chasis make overs - by fields 100 - 01-05-2015, 10:47 AM
RE: Chasis make overs - by morzh - 01-05-2015, 05:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
