Restored 1930s consoles +
That there is a Atwater Kent  model 317 from 1936, last year for Atwater Kent radios I believe.
Restored 1930s consoles + - by Fred Taylor - 01-05-2015, 01:19 AM
RE: Restored 1930s consoles + - by codefox1 - 01-05-2015, 05:54 AM
RE: Restored 1930s consoles + - by Fred Taylor - 01-05-2015, 10:38 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3323 online users. [Complete List]
» 1 Member(s) | 3322 Guest(s)
