Which code number?
Think I found my explanation. Seems the 37-34 and 38-34 Code 121 use the same chassis. Do you have this packet, Chuck?
Which code number? - by BrendaAnnD - 01-05-2015, 11:03 AM
RE: Which code number? - by Ron Ramirez - 01-05-2015, 11:11 AM
RE: Which code number? - by Chuck Schwark - 01-05-2015, 11:16 AM
RE: Which code number? - by BrendaAnnD - 01-05-2015, 11:50 AM
RE: Which code number? - by BrendaAnnD - 01-05-2015, 11:56 AM
RE: Which code number? - by Chuck Schwark - 01-05-2015, 12:01 PM
RE: Which code number? - by BrendaAnnD - 01-08-2015, 11:06 AM
RE: Which code number? - by BrendaAnnD - 01-09-2015, 01:11 PM
RE: Which code number? - by sam - 01-09-2015, 01:28 PM
RE: Which code number? - by BrendaAnnD - 01-09-2015, 01:32 PM
RE: Which code number? - by tom.seeger - 01-09-2015, 09:03 PM
RE: Which code number? - by jerryhawthorne - 01-10-2015, 12:45 AM
