Here we go with a Brand Z 9-S-262
Threads: 55
City: Lexington, KY
Ron, it also looks like someone put a homemade clutch assy on the tuning shaft, below is what it is supposed to look like:
[Image: http://www.philcoradio.com/images/phorum...62_037.jpg]
(picture from eBay seller csco1166)
That homemade assy might work OK, but if not you know what it should look like. Everything else is looking pretty good as long as the chassis doesn't reject that Philco capacitor
(This post was last modified: 01-06-2015, 01:28 AM by Eliot Ness.)
RE: Here we go with a Brand Z 9-S-262 - by Eliot Ness - 01-06-2015, 12:16 AM
Users browsing this thread: 15 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
