Philco 16b found dead
      Saved another,  heres how I got, rebuilt the cabinet ,next post will show it  refinished, then in electrical section will show the guts/before and after
Philco 16b found dead - by Fred Taylor - 01-06-2015, 12:32 AM
RE: Philco 16b found dead - by Geoff - 01-06-2015, 09:26 PM
RE: Philco 16b found dead - by codefox1 - 01-07-2015, 01:08 AM
There are currently 10172 online users. [Complete List]
» 1 Member(s) | 10171 Guest(s)
