Philco 16b is alive!
My apologies... I went to the garage and looked at the beat up front panels with a flashlight and they are veneer. They are in bad condition and jumped to a conclusion that they were photofinish. You would think that I would know better
than to jump to conclusions after all these years.. Icon_redface John
Philco 16b is alive! - by Fred Taylor - 01-06-2015, 12:50 AM
RE: Philco 16b is alive! - by John R - 01-06-2015, 12:47 PM
RE: Philco 16b is alive! - by morzh - 01-06-2015, 03:13 PM
RE: Philco 16b is alive! - by Ron Ramirez - 01-06-2015, 04:03 PM
RE: Philco 16b is alive! - by John R - 01-06-2015, 04:30 PM
RE: Philco 16b is alive! - by Geoff - 01-06-2015, 09:27 PM
RE: Philco 16b is alive! - by Art Hoch - 01-10-2015, 06:48 PM
RE: Philco 16b is alive! - by Arran - 01-11-2015, 01:20 AM
