pioneer sx1500td blowing fuse
Threads: 69
City: Kansas city, MO.
I will do that and post the results.
Do have one question. When you say there is no DC amps in device I thought the bridge diodes on the power board unit convereted the ac to dc and that became the B+ that went to other boards? Know that I'm not challenging you. I just want to learn as I go along. Thanks
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 10:16 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
