Whatzit on 42-1010
Phono Input Transformer, Part No. 89 on the schematic.
Whatzit on 42-1010 - by Jon Scaptura - 12-19-2005, 03:43 PM
[No subject] - by Chuck Schwark - 12-19-2005, 04:08 PM
[No subject] - by Jon Scaptura - 12-19-2005, 04:40 PM
[No subject] - by Chuck Schwark - 12-19-2005, 11:19 PM
There are currently 9425 online users. [Complete List]
» 2 Member(s) | 9423 Guest(s)
