Here we go with a Brand Z 9-S-262
Threads: 73
City: Riverside, CA
(01-08-2015, 01:20 AM)thirtiesradio Wrote: There is what looks like a clock main spring that keeps the play out of the tuning system as well as assisting to balance the tuning cap weight. It is attached to the tuning shaft. On the motorized sets it needs to have the right tension. On the earlier sets it is not critical. If it's too loose or tight, the motor will slow/speed up noticeably as you get to the higher frequencies on the dial.
Good point. I forgot about that spring. If I remember correctly I had to play around with that a little bit to get mine to work properly.
(This post was last modified: 01-08-2015, 01:53 AM by Geoff.)
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 01:52 AM
Users browsing this thread: 27 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
