Bakelite blocks in a 37-116????
     I am possibly going to be doing a chassis restoration on  Philco model 37-116.
        I have seen the radio at a glance and it looks like a 38-116 by the tuning dial,which is quite different than the 37-116.  My question is: approximately  how many Bakelite blocks are in this radio that need to be changed?
    Also how much of a challenge is this radio to recap?  I know it depends on the qualification of the person doing the work, but relative to a Rogers 10-12 how hard is it.
  Thanks in advance   Dan
Bakelite blocks in a 37-116???? - by Dan Walker - 01-08-2015, 02:36 PM
RE: Bakelite blocks in a 37-116???? - by David - 01-08-2015, 02:42 PM
RE: Bakelite blocks in a 37-116???? - by Kestas - 01-08-2015, 07:36 PM
RE: Bakelite blocks in a 37-116???? - by Warren - 01-08-2015, 07:46 PM
RE: Bakelite blocks in a 37-116???? - by 462ron - 01-08-2015, 08:00 PM
RE: Bakelite blocks in a 37-116???? - by morzh - 01-08-2015, 11:35 PM
RE: Bakelite blocks in a 37-116???? - by Nick3092 - 01-09-2015, 12:03 AM
RE: Bakelite blocks in a 37-116???? - by Arran - 11-13-2015, 03:58 AM
There are currently 5821 online users. [Complete List]
» 1 Member(s) | 5820 Guest(s)
