Which code number?
Sam,
That held the old 1V carbon batteries that were used for bias. It was a cute idea, and certainly made it simple to change the batteries back when you could still get them.
Which code number? - by BrendaAnnD - 01-05-2015, 11:03 AM
RE: Which code number? - by Ron Ramirez - 01-05-2015, 11:11 AM
RE: Which code number? - by Chuck Schwark - 01-05-2015, 11:16 AM
RE: Which code number? - by BrendaAnnD - 01-05-2015, 11:50 AM
RE: Which code number? - by BrendaAnnD - 01-05-2015, 11:56 AM
RE: Which code number? - by Chuck Schwark - 01-05-2015, 12:01 PM
RE: Which code number? - by BrendaAnnD - 01-08-2015, 11:06 AM
RE: Which code number? - by BrendaAnnD - 01-09-2015, 01:11 PM
RE: Which code number? - by sam - 01-09-2015, 01:28 PM
RE: Which code number? - by BrendaAnnD - 01-09-2015, 01:32 PM
RE: Which code number? - by tom.seeger - 01-09-2015, 09:03 PM
RE: Which code number? - by jerryhawthorne - 01-10-2015, 12:45 AM
