A cone crack - what is the best quick repair?
   On any speaker repair that I have done ,I used'' Pliabond''  It is made by Goodyear and it never gets hard.
        I am not sure where you can get it .. I get mine at Home Hardwar.
RE: A cone crack - what is the best quick repair? - by Dan Walker - 01-10-2015, 12:15 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3723 online users. [Complete List]
» 1 Member(s) | 3722 Guest(s)
