Philco 84 4989-AK Block
This block calls for (2) 0.09 Caps.
I only have a pair of 0.08 @ 630v. , will this work?
or do I need to find the exact ones or any equivalents you can suggest ?
thanks in advance
Philco 84 4989-AK Block - by rciancia - 01-10-2015, 12:59 PM
RE: Philco 84 4989-AK Block - by Chuck Schwark - 01-10-2015, 02:02 PM
RE: Philco 84 4989-AK Block - by rciancia - 01-10-2015, 02:21 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
There are currently 3158 online users. [Complete List]
» 3 Member(s) | 3155 Guest(s)
