Radio Newbie in need of some guidance for an 84
Connect the two negatives together and connect that to the center tap of the power transformer. Just like the diagram. If you connect the negatives to the chassis you will short out the bias voltage for the output tube.
Philco 84 - by rciancia - 01-07-2015, 09:18 PM
RE: Philco 84 - by KCMike - 01-07-2015, 11:22 PM
RE: Philco 84 - by BrendaAnnD - 01-07-2015, 11:53 PM
RE: Philco 84 - by morzh - 01-08-2015, 12:36 AM
RE: Philco 84 , Negative Side of Electrolytic Caps - by Radioroslyn - 01-10-2015, 08:45 PM
