HELP - Broken grille, Philco Tropic 41-758EZ
Hey Ron did you get your grille fixed? I saw today while looking for something to weld up a bad spot in cast iron block. Thought it should help you. They have stuff that is suppose to weld pot metal and everything else. Looks pretty good.
http://muggyweld.com/
RE: HELP - Broken grille, Philco Tropic 41-758EZ - by OZ4 - 01-11-2015, 02:35 PM
There are currently 4493 online users. [Complete List]
» 1 Member(s) | 4492 Guest(s)
