Almost Finished With The 39-30
(01-09-2015, 04:22 PM)philconerd Wrote:  This would be called  Refreshed  as it is not exactly looking factory new.
I have spent some time during the past few months working with this 39-30 fixer and finally it is almost done, as far as I can go.
I still have to make and install the Station Numbers for the push buttons.  I am amazed how well a lowly 6 tube receiver works!
Now on to the next project, whatever that is.......
G.
   Cabinet looks great , that's a nice radio. Good job
Almost Finished With The 39-30 - by philconerd - 01-09-2015, 04:22 PM
RE: Almost Finished With The 39-30 - by Fred Taylor - 01-11-2015, 05:10 PM
RE: Almost Finished With The 39-30 - by shaler78 - 01-12-2015, 09:42 PM
There are currently 5355 online users. [Complete List]
» 5 Member(s) | 5350 Guest(s)
AvatarAvatarAvatarAvatar
