Radio Newbie in need of some guidance for an 84
Threads: 2
City: Fleming Island, Florida
I just discovered that I mixed up the 490K and 240K resistor (#22 and 23 on the schematic).. had them reversed. Could that be the cause ? Here is a photo of the caps I am using and of my center tap (Yellow and green)
https://pbs.twimg.com/media/B7Hc-84IEAAYXSx.jpg
https://pbs.twimg.com/media/B7HdEYqIgAAp9oV.jpg
I am also ashamed to say I had a 500ohm resistor instead of a 500K. Newbie mistake.
Will replace them tomorrow. Do you think this could be the cause ?????
This picture explains where the error was..
https://pbs.twimg.com/media/B7HgNUfIcAAxTE-.jpg
(This post was last modified: 01-11-2015, 10:52 PM by rciancia.)
RE: Radio Newbie in need of some guidance for an 84 - by rciancia - 01-11-2015, 10:39 PM
Quick progress report:
Hi Rod,
Hello Tim,
