pioneer sx1500td blowing fuse
Threads: 562
SO, one of your transistors is fully open and another is fully closed. Namely, Q10 is closed. Which means that Q4 is fully open.
This sch with all transistors being OK cannot work like this. Make sure output AND the ones before them (Q6 and Q8 ) transistors are intact.
Q: how do you check them transistors?
RE: pioneer sx1500td blowing fuse - by morzh - 01-12-2015, 12:23 AM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 5208 online users. [Complete List] » 1 Member(s) | 5207 Guest(s)
