46-1201 Tuning Issues
Recapped my 46-1201, (Bing Crosby), and got the record player playing perfectly and with a new cartridge.  The odd thing is that when tuned to the radio side, unless I put my finger on the tuning condenser, I cannot get any broadcast channels.  When I touch it, the am channels come in loud and clear.  I tried attaching a wire to the condenser, but that only leaves garbled sounds, not clear at all unless I press on that condenser.  All the tubes tested strong also.  Does anyone have any idea what the issue is?  The phono plays loud and clear also.
One more thing, when the antenna is disconnected, the band picks up the same one or twostrange amateur or religious stations at many different spots on the band. Once I connect the 2 antenna leads, these stations go away.
46-1201 Tuning Issues - by davidff - 01-12-2015, 09:43 AM
RE: 46-1201 Tuning Issues - by codefox1 - 01-12-2015, 11:12 AM
RE: 46-1201 Tuning Issues - by davidff - 01-12-2015, 04:18 PM
There are currently 9450 online users. [Complete List]
» 1 Member(s) | 9449 Guest(s)
