Radio Newbie in need of some guidance for an 84
Unsoldered 6&7 from Filament Socket and the Center Tap(-Icon_cool
When placing an Ohm meter on 6 & 8 - 0
When placing an Ohm meter on 7 & 8 - 0
When placing an Ohm meter on 6 & 7 - 0.4-0.5
PRAYING I do not have a bad transformer. thoughts ?
Philco 84 - by rciancia - 01-07-2015, 09:18 PM
RE: Radio Newbie in need of some guidance for an 84 - by rciancia - 01-12-2015, 12:54 PM
RE: Philco 84 - by KCMike - 01-07-2015, 11:22 PM
RE: Philco 84 - by BrendaAnnD - 01-07-2015, 11:53 PM
RE: Philco 84 - by morzh - 01-08-2015, 12:36 AM
Users browsing this thread: 13 Guest(s)
