Almost Finished With The 39-30
Nice restoration job. You should be very happy with its performance. I have a 39-35, and it is surprisingly the best performing radio of my small collection. Ron has a very good link on this phorum for reproducing the station call letter tabs.
Almost Finished With The 39-30 - by philconerd - 01-09-2015, 04:22 PM
RE: Almost Finished With The 39-30 - by shaler78 - 01-12-2015, 09:42 PM
There are currently 6534 online users. [Complete List]
» 2 Member(s) | 6532 Guest(s)
